I’m not able to share an event recording from my Android phone to Whatsapp or anywhere else. I get a popup “Can’t send this video. Choose a different video and try again”. I have an iPhone too and it works perfectly on that! Is this an Android specific problem??
I am able to on both my Android phones, have you checked to make sure the permissions are set properly
I’m using Android as well, and I can send videos in the Whatsapp.
Wyzecam has all permissions. I have a galaxy S8. Any ideas what could be causing this problem?
I am not sure, I have an S9 and an S10 and can send on both of those. I have heard of issues before but not sure how they got fixed.
If you do a quick search for Whatsapp you can find a few threads about the issue and see if there are any clues that may steer you in the right direction.
Sometimes when my apps are acting weird, I restart my phone and everything starts working again. If you haven’t tried this already, it might solve the problem.
Did you find a solution to this? I’m having the same problem…
Instead of sharing directly from the wyze app, I’ve found that if I download the video to my phone I can then share it easily. Hope that works for you all…
I have the same problem. On BOTH my phones: Samsung s7 and my new Note 10+. If someone resolved it, can you please post it here in this thread?
