Wyse has responded to my ticket, and sent the following standard things to try, all of which I had already done, but went through them again anyway, and found a new app version as of this morning.
I post all this in hopes it also helps others that stumble here looking for answers as well.
I love all my Wyse devices!
Wyse said:
Let’s try the following steps:
Confirm your Wyze app is up to date. The Wyze app needs to be version 2.36 or newer.
In your Wyze app, navigate to the Account tab > tap About.
Your current app version will be listed beneath the Wyze logo.
Compare your app version to the latest app version listed here on our [Release Notes & Firmware page.
If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
Check that your Wyze Cam v3 Pro’s firmware is up to date.
You can check this by going to the Account tab > Firmware Update.
If there is an update available for the camera, please move forward with updating it.
Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
Factory reset the camera and then set it up as new.
Remove any microSD card inserted in the camera.
With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
Once the status light starts flashing red, set up the camera as new.
Reboot your router.
My Response:
It was App ver 2.36.0 (96 I think) this morning.
It is now 2.37.0 (b111)
Firmware version is 4.58.0.2905
Isn’t that data in the sent log?
Power cycled
Factory Reset
Network restarted
Network tested for speed, jitter, latency, packet loss, late packets, etc.
100 % good, no loss on upload or download.
I have made sure all other devices are not sending video up to the cloud, so that this is the only thing doing any streaming, and it doesn’t matter.
As my post has been getting responses on the forum, other people are having the same issue.
The recordings on the SD card are fine, no skips.
This would seem to be something to do with the streaming protocol, the servers in the middle on the cloud possibly, etc.
Confirmation from you saying that it is a known issue that you are working to correct with a target date would be nice.
If this is something that can’t be fixed quickly, I will be looking for a refund on 16 devices.
Thank you,
Jeff
