My pan cam v3 does not light up anymore. This happened randomly.
Any advice? It’s Les them 3 months old.
Can you try a different power brick and cord to test?
Call Support get a Warranty Replacement
Also, make sure your wall outlet or power strip is not tripped.
Welcome to the Forum, @iapalucciangelo! ![]()
Since you noted that this is a Cam Pan v3, please be aware that it’s supplied with a 5V ⎓ 2A power supply, whereas other Wyze Cams typically ship with a 5V ⎓ 1A power adapter. That will be important if you try testing with a different power adapter.
Having said that, though, with the age of this camera I’d definitely contact Support for a possible replacement.
I did. No go
