I dont have the option to activate PD on my cameras. That toggle is gone.
I guess I’ll just have to wait.
Maybe it’s an eastern thing
Nope. Not working.
What options do you have now.
Under “Event Recording”, you should have motion turned on.
In “Detection Settings,” you should have"Wyze AI Events" on.
I have just received a person detection notification as well as “person” tag beside the event
Wyze AI events toggle is not available.
PD never stopped working for me, but the one constant in these threads is that notifications stopped. Now it seems a few are getting notifications.
As is usual with server-based systems, it takes a while to get the fix out to all the servers.
What options do you have? Post a screenshot if you can.
Interesting… Check your services tab to see if Cam Plus or legacy PD (depending on what you are subscribed to) is shown there. If you don’t see anything, check services.wyze.com and make sure your subscription is shown there. If you don’t see anything there but you know you should be subscribed, you would have to contact support.
As for the sound events, have you double checked your event recording settings? It will be greyed out if you haven’t enabled recording when the cam detects sound.
Do you have the latest app version? There’s a new V3 firmware out today, did you update?
As of 9pm Eastern time, 22 minutes ago, my v2 cams with legacy person detection are back to properly recording events labeled Person. I did nothing to make this happen so it must be a server fix.
Edit: Adding some screenshots… Under Wyze app Home > Account > Services:
I have a bunch of v2 cams assigned to legacy person detection (Pilot):
Under Settings > Event Recording for each v2 cam, Detects motion is enabled:
Under Settings > Notifications for each v2 cam, Notifications are enabled, but no type is enabled because Person is missing and I don’t want a notification for anything other than people:
But, mysteriously, I’m getting Person notifications. At least it’s working.
My AOS app is up to date, and no firmware updates are showing. I guess I’ll just wait and see if they are working tomorrow, or after the Feb 3 “maintenance”.
Thanks fellow users.
For crying in the sink, now I’m getting motion notifications for two cameras that have motion notifications turned off
My husband accidentally set off our burglar alarm tonight and cameras didn’t detect anything! No sound notifications or event recording. I have Cam Plus person detection and it’s a rarity when it records someone walking by. What’s going on with these cameras? They used to work great and now they hardly ever work!
Hi, everyone! Sorry for the person detection problems. The team was able to figure out what went funky to resolve it and are looking deeper into what happened here.
If you are still have trouble with person detection, please reach out to our support team.
And what is the best way to do this? By this I mean that I would actually receive a response from someone. Thank you.
Thanks for update finally. If the issue is known, why inundate support with more reports? Seems counter productive.
Unless you mean it’s fix and we should start getting the correct labels on events and if we’re not then call in.
Wow - Wyze finally acknowledges and responds 4 days thats 4 days after the problem started.
So its not resolved yet?
I got my first notification this morning after 4-days.
Still not having any person detections.
