When my LG phones are locked, no notification but as I unlock, they flood in. Have re-installed and still nothing. Any suggestions would be helpful.
There are several threads about this issue. Search the forums for Android notifications. Basically it’s caused by a battery saving feature in Android called Doze. There is a way to disable doze but requires a adb command, does not require root access.
This might help.
No, it won’t
