. The issue is; all cameras suddenly have no “cam lite” cloud events for 48 hours now. Cams are regular Wyze v2 and v3 and all are “subscribed” to cam lite package—free 12s clips with 5s cool downs. If you can’t no biggie.
Can you check the event recording settings and detection settings. Also, make sure you don’t have any filters enabled in the events tab. Hit reset filters.
I have 4 of the battery powered WCO version 1 all on CP Lite and they have been recording 12 seconds events everyday. There is a crazy squirrel that has been tormenting one of my cams all day today. The WCO has a 1 min cooldown but the squirrel is try to make a full length motion picture. I’m glad I turned off scheduled event recording to the SD card.
I am having the same issue with 5 V2 cams and 1 V3 outdoor cam. Very frustrating, hopefully it is from my recent update and they’re working on a bug fix. No events for 2 days now
There’s another thread on this very same issue:
UPDATE:
They seem to have fixed the issue on the Wyze side per another thread.
Thanks for the heads up .
