Events not being recorded lately
One of my cams isn’t detecting any events. Camera is facing the front yard and i have no events for today despite people coming and going. I checked all the settings, nothing has been changed
I had this happen to my Wyze Cam V3 the other day. I restarted the camera via the app and everything has been fine since. Not sure why that was needed but worth a try.
Reset as in factory reset or turn off and on?
I would unplug it and plug it back in
Also make sure you don’t have any filters enabled in the events tab.
It was Settings > Restart Camera > Restart [button]
Now I have a rule to restart several cameras once a week just in case.
I restart via app. Worked for 1 event recording. Unplugged fir a min, also worked for 1 event recording. But nothing since. 10 hours ago
What is your detection level set at? Do you have motion tagging turned on and see the green box for motions?
Also, what kind of camera do you have? Is it also Wyze Cam V3? Does it have Cam Plus or Cam Plus Lite?
Its set to 100. Motion tag is on. Its v3 cam with cam plus.
It’s working. Had to do a factory reset
Hope this lasts. :+1:
