Night lights as under cabinet lighting?
Has anyone tried using the night lights as under cabinet kitchen lighting?? They seem to have all the features i want but not sure if the light placement would work or if they are slim enough.
Not sure you will get the amount of lighting you are looking for. When mounted, the lights take up 5\8 inch from the wall. Also, the light is directed from the sides of the light. If mounted under a cabinet, there wouldn’t be much downward light onto the counter at all. Lastly, the lights are motion activated but don’t stay on for very long. Since they are not Smart Lights and don’t connect thru the app, you would either be waving under the counter constantly or pulling them down all the time to turn them on and off.
Awesome, thanks for the insight!
