I am installing a brand new wyze pan v3 camera. After plug in the power, there is no any response, whatever how long I pressed the reset button? Is this a dead one?
I am using the original power code.
Make sure the 90-degree USB connector is seated tight. Press hard. If it’s not, then there’s no power.
To add to p2788deal… also you can take a good working cable (non-90degree) and plug it directly into the camera (without the mount) to check for power.
