This New Wyze Cam App is a piece of crap. My Apo just updated today 07/08/2924. WRNT to look at cams before going to bed and notice the new App. Opened it up and out of 8 cameras only 2 are being shown and those 2 keep refreshing .
Can someone please tell me how I can view my cameras??
Wyze what in the heck have you done???
I strongly agree, I hope they upgrade it soon. The views are slow to update, and I can’t figure out how to delete a camera now. Total junk!
The Favorites tab is now the place for your main landing page. Go to the device tab and select/de-select those devices and groups that you want to see on Favs. Once added, you can drag them around to sort as you please. You can also add shortcuts there.
3.0 app needs help fast! Home Screen Loading Livestream is waaaaay too slow, almost unusable. At a minimum make this live loading an OPTION… very soon please!
I happened to be using my Wyze vacuum at the exact time the application was upgraded (without even asking me). I had vacuumed two rooms that morning using the same network and vacuum that I have used for literally years. The network supports both 2.4Ghz and 5Ghz clients. After the app upgrade my vacuum didn’t work. I deleted it and tried to reload it into the new app. This seems to be the only fix that ever works when the Wyze Vac misbehaves. When I get to the “select Network” portion of the setup I see the correct network name but it has a warning that “5G networks are not supported”. At that point I cannot move forward. No changes have been made to the network - only the change in the Wyze app. the network current supports many 2.4Ghz clients. Has anyone else run into this and is there a work-around?
