Has anyone experienced white noise or static on the live audio feed on the new v2 floodlight?
I recently installed one and have noticed this issue. I had the older version camera/floodlight and replaced it with the new v2. The location is exactly where the old one was. It was working fine. Nothing had changed in the environment eg new electrical devices. All my other older version lights work fine. I have toggled settings back and forth with no difference. Seems to be an issue with new floodlight and or firmware. New update was installed yesterday with no difference. Any help?
I have the new flood light and the same issue. Static and sometimes a screeching electronic sound.
Yes. That noise as well. I submitted this to wyze support to investigate. So who knows when or if this will ever get fixed.
I have the V1 floodlight and about a month ago, I started to have the same problem where there is a constant static/white noise on the live audio feeds. My SD audio recordings have no sound and Wyze has no solutions for that.
