The new interface seems that is has made the sd card recordings complicated to access. If this change is permanent I will be forced to go to another camera system. Hope this is corrected.
Welcome @cli.jonmutch
Can you explain what the complication is? I have found tapping on the SD Card during the Live Stream works just fine. you then have access to all recordings on the SD Card.
Thanks
