Network Connectivity
The location I want to set up my camera requires both a username and password for setup. I cannot find any way to enter a username in the setup of my camera. Looking for suggestions
Welcome to the user community @jonauge!
You may find some answers in other thread topics in the forum discussing the same issue depending on your specific WiFi setup configuration. But, I don’t think you will be able to connect Wyze to a network that requires both a Username and a Password. I think you will need additional hardware for that. Wyze hardware is set up for password only when you identify the network you want to log into.
Suggest you read thru these posts and send a reply to someone who has solved the problem. Good luck!
