I’ve seen these no-drilling mounts you can use for vinyl siding but they don’t look as if they would work with the battery cam pro setup. Any recommendations for something like this are appreciated.
These have been working well for my BCP cams attached to vinyl siding. Reverse the 2 adjustment screws so the thumb knobs are against the siding for a more stable mount:
Thanks. I bought some and they work great!
Great to hear and thank you for reporting back. I’ve been using these same mounts for everything since Cam v2.
Need an adapter for Cam OG though. ![]()
