Name Device: Operation Failed. Unable to complete setup of Wyze v3
The subscription ties to your account and not to the camera. What I would do is the following:
  1. Remove Cam Plus from the Camea
  2. Remove the Camera from your account
  3. set it up on your daughters account and then add a new Cam Plus subscription to her account. After you do that, you can select the camera to assign the new Cam Plus subscription to.
If you do this, your Cam Plus will be available for another camera on your account.
BTW: I removed your personal information from the post. This is a community forum and posting of personal information is prohibitive and could put you at risk. Just wanted to let you know.
Really appreciate all your and WyzeDesmonds help getting us all back in business!
Getting the same operation failed error when adding a Wyze light switch. Is there any solution?
Unable to add switches
Stops at naming the device with operation failed
I am having this same problem with my wyze outdoor cam. I get theough the setup process until it has me name the device, but no matter what i try, it says “operation failed” and will not let me complete setup. Please help! Thanks!
I am also having this same issue with a wyze light switch.
Having the same issue, Was there any updates that would assist?
Hi Wyze team… Is there any workarounds for this problem yet?
Same issue here, with my Wyze Outdoor v2 camera. I’ve had these for years and have never had this issue.
Bought a replacement cam 2 weeks ago and it quickly connected. The new one I bought within the last week says the connection was successful but when I go to name it it says operation failed. Yet the camera shows up in the app - it says it’s not connected to a base station though.
I’ve attempted this over 10 times in the last 2 days, tried the usual modem and base station reboots, no luck.
Did you tap on the Base Station and tap Add Wyze Cam Outdoor to link the two together?
If you are facing the same issue, What i did to resolve mine was at the device name setup screen. I used xx, yy and zz to name it and click save multiple times. and also pressed the Sync button on the Wifi Transciever of the Wyze Outdoor cam.
As soon as I did this and closed the app on my smartphone and reopened. It started livestreaming.
Please try and update if it works for you.
Thank you. I will try and report back if this works!
I actually heard from Wyze yesterday in the customer service chat that “several customers are having the same issue”. They are looking into it. If your fix doesn’t work I will bug them again in a few days.
Same problem both Outdoor Cams - they register, accept the cam plus activation but “operation failed” for naming. Is this being resolved manually in your DB by device MAC for the time being? I sure hope not.
Canceling my wyzz cam plus subscription…im on my 3rd outdoor cam.nothing but problems.
Got 1 as a gift and gor no email back about returning it… cam just 1 day failed to turn on at all and it wont charge or work.
Now i got another brand new cam i bought and it the wyzz outdoor cam fails to accept name on last step to FINISH wyze set up.
So frustrated…the new update seems to have caused major issues.
If this isnt fixed in 48hrs im going to buy all RING cams and leave a horrible BBB bette businesses bureau review since this company doeent care about its customers and has inept at best service.
Look at all the complaints here on the forums.
I am having the same exact problem with the same exact error code with the same exact outdoor camera. I hope they find a solution for this like they have with some other cameras who had the same issue early in the year.
Wyzee outdoor v2 cam not taking name problem SOLVED
PROBLEM SOLVED.
  1. 32gb sd card
    2).follow the wyzz dorections to manyally flash.
  2. make sure to out the darn fold as “Sdcard” as they state in directions
  3. turn off wyzz outdoor cam put in sd card
  4. i had mine nect to base station
  5. it will flash blue andyellow then stop at blue then mine went yellow.
  6. i turned off camera took out sd card
  7. turned on and went back to
    add device
    Wyzee outdoor
    Etc and it worked finally
Having the same issue.
Did you follow the manual steps for sdcard flash?,
Its not super hard…its a bunch of steps but it worked
Sorry if this sounds dumb, but I do not have an sd card and it was my understanding you needed one to do that. Any help is appreciated and thank you for the suggestion!
I flashed w 38gb sd and it finally worked…the outdoor v2 wouldn’t update otherwise and I think they stopped making them.they are all sold out now
