Name Device: Operation Failed. Unable to complete setup of Wyze v3
same here you hit finish and stays on “Name Your Cam”.
Hi there, I am having this issue and have tried several times to add the device. Leaving for a trip tonight and wanted to have set up. :pensive:
I’m having the same issue. I tried all the things listed. Can you help me please?
WYZE Cam OG
*operation failed at Name Your Camera
Let me add another failure to the list. This is not a good first user experience. Wyze Video Doorbell Pro. Right now it’s a dumb doorbell. And the fact that I have to remove it each time to do the add device process is super annoying.
Seen quite a few posts on this same issue today. At least you’re not alone.
I am having this same issue with the OG cam
I literally came here because I’m having the same issue with the OG smh
Same here with the OG cam. Cannot name it, operation failed
I was just trying to set up a new camera and same issue, operation fails when naming device. I’ve cancelled, closed app and retried 4 times with no luck. I have a Wyze camera OG
Same problem. OG says operation failed when i try to name it. I have four other cameras working fine right now on this network. Figured I’d post to see if they offer us a fix.
I am having the same problem as well. I am trying to setup wyze cam og. Please help us.
Having the same issue, just got my doorbell today, support has been less than helpful. I’ll give it a day and return it tomorrow.
Maybe @spamoni can help.
Glad I found this thread after resetting on my end multiple times. Trying to setup Doorbell Pro and also failing at the Naming Stage. Will stay tuned for an update!
Will add to list. Trying to get eyes on this now.
Can you please proceed see a log
Same issue with OG camera, won’t let you name. I also have a new V3 and it worked when I set it up after OG wouldn’t.
Solutions please? Have reset and tried several times.
Reporting it and trying to get this looked into.
I will update post if I hear anything.
I’m having the exact same issue right now with my Wyze Doorbell Pro. I have reset routers closed app and retried 5-6 times. I keep getting the operation error at the naming part
Same here. Come on Wyze, get this crap fixed.
