My trusted device
Does anyone have as a trusted device Chrome 39c
I’m unclear what you are asking exactly. Do you mean does anyone using Chrome to log in to their Wyze account on the Wyze Website select this is a trusted device for the Wyze account while logging in with 2 factor authentication through the browser?
If that is your question, then yes, I do select that.
If you mean when you try to log into the app and it takes you to chrome to login, then yes, I do select that as well while in chrome.
If you mean something else, can you clarify?
