My network has changed to 5g
My network has changed to 5g. Are any of my cameras, light bulbs and smart plugs compatible?
What cameras do you have? Most of the older cameras and other WYZE items all work on the 2.4GHz network. There are only a couple of the newer cameras that will work on the 5.0GHz network. Are you sure you only have a 5.0GHz Wi-Fi network???
Smart plugs are 2.4GHZ
Light bulbs say 2.4GHZ/Bluetooth?
If your WiFi REALLY is 5GHz only and you can not change that, add a second access point that is 2.4 GHz only. Fortunately the likelyhood is that someone you know has one laying around not being used (because they upgraded). Even if you have to go buy one, they are really inexpensive.
I doubt your network has changed to 5G. It might include 5 GHz, unlikely is using 5G cellular service that your cell phone is.
5 GHz WiFi is not the same thing as 5G. 5G is the Fifth generation of cellular service, not local (usually home) network frequency.
Your Wyze devices are not connecting to 5G regardless, they don’t have cellular radios. And your home WiFi that is likely also 5 GHz is not connecting to Wyze devices.
As explained by the knowledgeable and helpful guys above, There is a difference between 5GHz and 5G Celluar.
What I am guessing happened to cause confusion to you is one of 2 things:
  1. You got a mobile hotspot Router from a phone company like T-Mobile or Verizon and that hotspot router connects to the phone company through 5G Wireless data. BUT it will then broadcast internet through the router in 2.4GHz and 5GHz for other devices to connect to it (laptops, phones, TV’s, Smart cameras, etc). They will connect to the router through 2.4GHz (or 5GHz) and then the router will connect to the phone company internet provider through 5th-Generation Wireless standards (5G).
  2. You bought a new phone that uses 5G mobile data with your phone carrier, and you are thinking that means your phone has to connect to your camera through that 5G connection. That’s not how it works. Your phone still connects to the internet through 5G when you are not connected to a WiFi router, but all your other devices still connect to your home router through 2.4GHz as they always have. Then your home router and your Phone Provider will connect to each other so you connect to your camera through the internet that way. Your cameras will still work the same as they always have before your phone upgrade or your phone plan upgrade. That doesn’t affect anything.
I hope that helps.
I changed everything back to my old network. Thanks everyone for your help
I just read all of your post twice lol and I think I got it. I was thinking of switching to T-Mobile 5g Home Internet as my provider and I wanted to make sure my cameras will connect???
Absolutely, they will still connect. If you switch to a new provider or router, you have 2 options when your new router comes in:
  1. Set the new router to have the same network name and password as your last router used. Then ALL your devices will automatically connect to the new router (you might have to restart them first).
  2. If you’re going to use a new network name and password than your last router had, you’ll have to go through setup again on your cameras and select the new network. Then they’ll connect again and work as normal. No big deal. Don’t delete the cameras from the app first or anything, just tell they app you’re setting up a new camera and go through setup and it will update to the new network and have you name it again (you can choose the same name for the camera as you already have for it), but most of your other settings and rules, etc should stay the same. You don’t generally have to redo everything all over again as long as you didn’t delete it from the app, so it’s not too bad. But I’d still review all your settings again just to make sure.
Either way, you’ll be totally fine to switch to T-Mobile Internet. My parents had it for a long time and it worked fine. We have several other users in here that use T-Mobile Home Internet hotspot too. You’ll be totally fine.
So I’m trying to follow your instructions about not deleting the cameras and adding a new one but I must be doing something wrong because it’s not working for me. Is there a post or a page that’s been written about how to do this maybe? that you could direct me to?
No different than when you originally set up your cameras. Press the + symbol in the app to add a new camera. Follow the instructions. As stated, do NOT delete the camera first.
As stated above, Just pretend you’re setting up a brand new camera.
On the main home tab, tap the plus sign, choose Add Device, then select Cameras, choose the camera type, and then follow the setup instructions.
If it’s still not working for you, can you explain what part is failing?
I was also told by the spectrum cable guy that none of my cameras will work with my new modem router set up glass modem died, and had upgrade now I need to find a camera that will work
I think the v4 cameras work with the new spectrum routers
