I would like to move the sensor hub from one of my cameras to another. What is the process to move? Have to remove in gui…etc? I’m running beta on both cams (v2).
Just move it. The sensors are assigned to the bridge, not the cam. When the bridge repowers in the new location it will automatically go out and look for the sensors.
Great - thanks!
I moved my sense bridge from an old V1 cam to a V2 cam and unfortunately none of my sensors are reconnecting. I’ve tried removing and reinserting batteries in the sensors with no luck so far.
Did you determine a fix for this? I am having the same issue
