If you have moved a motion sensor, what glue/tape did you use to affix it in the new location? I am thinking about using removable 1 inch squares from the Scotch brand.
I’ve had good luck using 3M Command Strips, but any double-sided adhesive tape should work. I find Command strips stick to most (clean) surfaces for long periods of time while still being easy to remove later without damaging the surface.
