Move sense bridge
I need to move a sense bridge to a cam closer to a sensor. It’s currently in a wyze cam and want to move it to a pan cam.
Do I just remove it and place in the other cam or is there a procedure to move it?
I originally installed three sensors on a bridge, tested them, and everything worked well – except that one sensor displayed only 1 bar of transmission power. So, I turned the camera off, removed the bridge, and re-installed the bridge on another camera. When I turned that camera “On”, the bridge and sensors worked fine. There was no need to uninstall and then re-install the sensors once they are added to a bridge.
Worked like a champ, thanks.
