I want to reposition two of the WyzaCams which are attached to the drywall using the magnetic discs – what’s the best way to remove the double-sided 3M sticky pad (ideally without damaging drywall) and what’s the best way to attach the magnets in the new location?
You probably could use something like this and it would work for you.
Goo Gone Original Liquid - 8 Ounce and Sticker Lifter - Surface Safe Adhesive Remover Safely Removes Stickers Labels Decals Residue Tape Chewing Gum Grease Tar Crayon Glue https://www.amazon.com/dp/B07PW7J8QG/ref=cm_sw_r_cp_apa_i_y3C7DbRSBRVJ6
