Can the Pan cam be mounted inverted?
Could it be used outdoors if protected from rain and snow.
I’ve got two mounted that way. Here’s one. It’s under the deck, and I used a plastic lid from an old storage bin as a cover.
Oops. Turn your head sideways.
Great idea! Where did you buy the mounting screws and nuts ? What are their sizes ? Thanks!
Perfect! Thanks. Ill be mounting under the house as well.
I used a small metal shelf bracket. I drilled one of the holes larger for the 1/4-20 bolt. It is screwed to the post with simple drywall screws. You’ll need a short 1/4-20 bolt, and at least one nut to secure it. Maybe another nut or some washers as spacers.
