Motion Sensors: Failure
For some reason this morning, all motion sensors connected to the same camera/bridge ceased to function. That being, none of the rules associated with this camera/bridge would work. All are set to turn on Wyze light bulbs in various rooms nearby and have worked for years. But not today.
I have power cycled the camera and bridge a few times with negative results.
Is this a known issue? Suggestions?
Thanks
Wyze server code has trouble with v1 cams. once powered off won’t reconnect.
sensors attached will be off too.
send your Log(S) in.
post it in Fix it Friday as well.
I’m having the same issue with two sensor bridges. I think this started with the latest app update today.
Success! I found that disabling then re-enabling the rules associated with the affected sensors solved the issue. At least for now.
