I have my Home Monitoring SWystem disarmed but my Wyze phone app keeps alerting me of motion as I walk around. What gives here? How can I eliminate this annoyance?
Check the alert settings on the motion sensors. They will still send alerts if enabled, regardless of the status of HMS.
@WildBill, Thanks. Do you mean the “Notifications?” Turning notifications off seems to stop it, but do I need to turn that back on, or will the notification come on when I arm the system?
Two separate things. You should receive alerts from HMS from any alarms you activate in your Home or Away settings when you arm the system in those modes. Give it test, just to be sure. Setting for the sensors shouldn’t matter, in those cases.
