I found a app on windows store that claims to work with wyze cams. but when u go log in it says to enable 3rd party integration. it cost me 4.99 anyone know about this?
Continuing the discussion from Greetings!:
No. It would help if you pointed out the application you’re talking about.
Edit: found it at
https://www.microsoft.com/en-us/p/monitor-for-wyze/9p4dc0plmjzf?activetab=pivot:overviewtab
I wouldn’t if I where you …
I don’t see anything about Wyze certification or being endorsed by Wyze…
I would be reluctant to provide any Wyze login info to a third party…
Thank You All! it is Junk. I had Unfortunately purchased it before i had asked this question. I have not had any response from Wyze or the app Maker. If there is a app that is supported I would love to hear about it.
