MicroSd card size chart for all Wyze Cams
I found this out from a chat session. I wish it was simple to find on your website.
(10:11:08 AM) Denise Aubrey : Wyze Cams are compatible with class 10 microSD cards in the formats FAT32 and exFAT.
• For cards size 8GB, 16GB, and 32GB, we recommend using the format FAT32.
• For cards size 64GB, 128GB, and 256GB, we recommend using the format exFAT.
Please note that compatibility with microSD cards using exFAT format is currently available for the following devices:
• Wyze Cam Floodlight
• Wyze Cam OG
• Wyze Cam OG Telephoto 3x
• Wyze Cam Outdoor v1/v2
• Wyze Cam Pan v2/v3
• Wyze Cam v3
Please make sure you vote for your request as the system does not add your vote.
Also - for clarity, you are looking for a central location for SD Card options and formatting per camera something like below:
NOTE: The X in the Chart with the Cameras are only there for display purposes. By no means has this been vetted. The image is only used for Clarification.
Why does Cam v2 have no options listed? I have these cameras and they have a Micro SD slot. Wyze sells 32 GB cards for these cameras and this thread says 64GB work: What is the Largest Memory size you put in your Wyze Cam V2? - #7 by WyzeJasonJ
At the time individuals were interested in the new cameras. My intent was to update it over time. But, lost track of it.
Thanks for pointing this out. I will see if I can update it soon
I happened across this topic recently while looking for information for another topic. If your intent is to update the chart, then maybe a Markdown table would be helpful?
Click to expand if you want to see the code, which is definitely incomplete and a potential work in progress.
# Wyze Cam µSD Card Compatibility Chart
|Cam|8 GB (FAT32)|16 GB (FAT32)|32 GB (FAT32)|64 GB (exFAT)|128 GB (exFAT)|256 GB (exFAT)|512 GB (exFAT)|
|v1||||||||
|[v2](https://www.wyze.com/products/wyze-cam-v2)|||:green_circle:||:green_circle:|:green_circle:^[Per Q&A with Wyze-E bot on [the Support site](https://go.wyze.com/help):<br /><br /><em>What microSD card can I use in Cam v2?</em><br /><blockquote>The **[Wyze Cam v2](https://www.wyze.com/products/wyze-cam-v2)** is compatible with **Wyze MicroSD Cards** in the following sizes:<br /><ul><li>**32GB microSDHC Card**</li><li>**128GB microSDXC Card**</li><li>**256GB microSDXC Card**</li></ul></blockquote>]||
|[v3](https://www.wyze.com/products/wyze-cam-v3)|:green_circle:|:green_circle:|:green_circle:|:green_circle:^[Per Wyze-E:  "**Note**: Compatibility with larger cards (64 GB and above) requires Wyze Cam v3 firmware version **4.36.8.15** or newer. Cards larger than 256 GB may work, but they have not been tested."]|:green_circle:|:green_circle:|:yellow_circle:^[This is an assumption based on the previous footnote and could use a reference.]|
|[v4](https://www.wyze.com/products/wyze-cam)|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:^[![Cam v4 supports &micro;SD cards up to 512 GB](https://us1.discourse-cdn.com/wyze/original/3X/0/8/08c56f06fc3ed674704a473cefe013808d4e1abd.jpeg "Cam v4 supports &micro;SD cards up to 512 GB")<br /><br />See also:  https://forums.wyze.com/t/wyze-cam-v4-released-3-26-2024/294271<br /><br />Looking at some Help Center articles and the [Cam v4 product page](https://www.wyze.com/products/wyze-cam) recently, it appears that Wyze has changed a number of sources to now show a maximum of 256 GB for that Cam, and some of those changes have been fairly recent.  Why this change has been made hasn't been shared publicly, but it's still possible to find references to 512 GB card support for Cam v4.]|
|[OG (Standard)](https://www.wyze.com/products/wyze-cam-og)|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:yellow_circle:^[https://forums.wyze.com/t/og-cam-will-not-recognize-256gb-sd-card/282728/10?u=crease]|
|[OG Telephoto](https://www.wyze.com/products/wyze-cam-og-telephoto)|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:|:green_circle:||
### Key:
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :green_circle: = Officially supported.
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; :yellow_circle: = Not officially supported but users have reported success.
Click to expand if you want to see the result of the code from above.
Cam 8 GB (FAT32) 16 GB (FAT32) 32 GB (FAT32) 64 GB (exFAT) 128 GB (exFAT) 256 GB (exFAT) 512 GB (exFAT)
v1
v2 :green_circle: :green_circle: :green_circle:[1]
v3 :green_circle: :green_circle: :green_circle: :green_circle:[2] :green_circle: :green_circle: :yellow_circle:[3]
v4 :green_circle: :green_circle: :green_circle: :green_circle: :green_circle: :green_circle: :green_circle:[4]
OG (Standard) :green_circle: :green_circle: :green_circle: :green_circle: :green_circle: :green_circle: :yellow_circle:[5]
OG Telephoto :green_circle: :green_circle: :green_circle: :green_circle: :green_circle: :green_circle:
Key:
It’s something you could stick in the second post above and update as needed, adding rows for new products, potentially columns for additional capacities, footnotes as references or explanatory notes, etc.
On the other hand, that could be a lot to maintain when users can just visit Support and ask the Wyze-E robot (like I did with Cam v2; asking about Cam v1 gave no useful answer) if/when there’s a question about a specific Cam. :man_shrugging:
  1. Per Q&A with Wyze-E bot on the Support site:
    The Wyze Cam v2 is compatible with Wyze MicroSD Cards in the following sizes:
    • 32GB microSDHC Card
    • 128GB microSDXC Card
    • 256GB microSDXC Card
  2. Per Wyze-E: “Note: Compatibility with larger cards (64 GB and above) requires Wyze Cam v3 firmware version 4.36.8.15 or newer. Cards larger than 256 GB may work, but they have not been tested.” ↩︎
  3. This is an assumption based on the previous footnote and could use a reference. ↩︎
  4. See also: Wyze Cam v4 - Released 3/26/2024
    Looking at some Help Center articles and the Cam v4 product page recently, it appears that Wyze has changed a number of sources to now show a maximum of 256 GB for that Cam, and some of those changes have been fairly recent. Why this change has been made hasn’t been shared publicly, but it’s still possible to find references to 512 GB card support for Cam v4. ↩︎
  5. ↩︎
