Lost power adapter
I lost my Wyze Cam Pan power adapter. I have a 16 ft cable, like the one provided with the Cam Pan (USB-A to USB-Micro) to connect a power adapter to the Cam Pan. Looking online I can’t find a replacement power adapter (5V, 2000 mA) that will connect to the USB Micro end of the cable. I can’t find any cable adapters or couplers that would solve my problem.
These work as an example.
https://www.amazon.com/Abosi-Certified-Universal-Compatible-AB-95/dp/B076C58YMX/ref=sr_1_9?crid=17Q77Z36WXD60&keywords=usb+power+adapter&qid=1573231015&sprefix=usb+power+%2Caps%2C160&sr=8-9
By the way the camera connects to the USB Micro end. Not the adapter. The USB A connector on the camera is to supply power to another camera with. A daisy chain if you will.
Almost any adapter (wall wart) that puts out 2AH or more for USB will do.
I use these…
https://www.amazon.com/Certified-Charger-FONKEN-universal-Compatible/dp/B07DCR29GN/
…they work well for just about everything I have that needs 2A or less.
Thank you!
