Replacement power cable pan v3
My hamster chewed through the cable and now I need a new one. Has anyone found one that works since it needs to be very specific?
I don’t think Wyze sells the cable separately, but the new outdoor power adapter v2 includes an adapter.
Welcome to the Wyze User Community Forum @Reatta80! :raising_hand_man:
Because that 90° plug is specific to the cam, you aren’t going to find an easy replacement short of the pigtail adapter @IEatBeans mentioned.
However, if you are handy, you might be able to repair it or put a new plug on the power adapter end. Since the cord is power only, there should only be 2 wires in the cord that need to be reconnected. Alternatively, you can replace the USB-A end with one of these:
I have decided to get a different mount for this. This should fix my problem. Arrives tomorrow.
Here’s the link if anyone is looking for one.
Koroao 怐Latest Version怑 Indoor/Outdoor Security Wall Mount for All Arlo Camera, Wyze Cam Pan/V3, Arlo Ultra, Arlo Essential, eufyCam 2 - More Stable and Flexible Arlo Accessories(2Pack, White) Amazon.com
