Lost Cam Plus
All my cameras were included in Cam Plus, but when I had to factory reset a V3 and re-add it to the app I am now being asked to pay for Cam Plus for this camera. How do I get it re-included in Cam Plus. I originally paid for all cameras. Thanks,
Here is what I have done in the past:
  • Start the app
  • Tap on the Account Menu
  • Tap on Cam Plus square top Right
  • Scroll down to ā€œFree License - Select Deviceā€ and select it
  • In the window that appears, select the camera to add (a Check Mark should appear next to it)
  • Tap on the screen above the window (SHould be a grey area) to close the popup.
That should be all you need to do.
Open a wyze service ticket
Thanks. That appears to have resolved the problem!
