Looking for Users Experiencing SD Card Issues (Cam Pan v3 / v4, Cam v3 / v4)
Hi everyone, our Wyze team is currently working to improve SD card reliability on Cam Pan v3, Cam Pan v4, Cam v3, and Cam v4. We are looking for users who are experiencing SD card related issues and are willing to share more information to help with our investigation.
If you are seeing issues such as recording stopping, SD card not recognized, or “No Video Available,” we would really appreciate your help. If you are willing to participate, please reply to this post or send me a direct message with the following details:
  • MAC address of the affected camera(s)
  • Camera model
  • Firmware version
  • SD card brand, model, and capacity. Photos of both sides of the SD card would also be very helpful if possible
  • Approximately how long recording runs before stopping
  • Whether you see any error messages in the app
  • Whether the SD card has been formatted
  • Whether this started after a firmware update
If possible, please also try the following steps and let us know the results:
  1. Remove the SD card, wait about 10 seconds, then reinsert it. Please note whether you hear the “ding-ding” sound.
  2. If there is no “ding-ding” sound, please check whether the SD card can be read and written normally on a computer.
  3. If the SD card works normally on a computer, please back up any important data and format the SD card.
  4. Reinsert the SD card into the camera. If you hear the “ding-ding” sound, please wait at least 1 minute and check whether recording resumes.
  5. If the issue persists after these steps, please submit a device log through the Wyze app. When submitting the log, please note whether you performed the steps above and include the Log ID.
Thank you very much for your time and for helping us improve Wyze products.
I’ve had few problems with a variety of 32gb SD cards, when I do a long Fat32 formatting of them prior to use. If they start to have issues, doing the long formatting again, usually resolves the issue.
I stopped doing fast formats etc… to many issues.
I had a V3 pan that had constant SD issues and one that was fine.
I gave up on the bad V3 pan and gave it to another forum member, maybe they can chime in?
It was a issue for so long that I gave up on Wyze…..
Hi, thank you for sharing this! We appreciate the detailed insight.
Sorry to hear it’s been frustrating. If you’re open to it, any additional details about the Pan V3 that had issues would still be very helpful for our investigation. Thank you for sharing.
I highly recommend anyone having SD Card issues assist with this investigation.
I recently had five v3 Cam Pans sent back (and replaced) for this issue. Hopefully my returned devices are being studied for what the cause might have been.
I’m having SD issues with my floodlight pro. This will the the 4th time in maybe 4 months I’ve had to reseat the SD card. I’m using the one that was included in the package. Maybe going to swap it out to a different card, I don’t really have many other issues with my other cams, just have to reset my thermostat about once a month because it loses connection, sucks ripping that thing off the wall so often to do that. Also with there was an easier way. While I’m here, I’d love to see smart smoke alarms/CO2 detectors. Would be a nice added touch and very helpful. I will submit a ticket for the floodlight pro and send my logs. Hate having to bust the ladder out and climb up there to keep doing this. Esp in the winter. Thanks for investigating this.
It’s the new rtsp thing that’s causing problems with my v3 and when I click as card, nothing happens. Live screen is always frozen always disconnects from home wifi when movement detected.
Sent my info. Pan cam v3.
Issue probably started around 09/2024. I tried many different SD cards and none would work. Some might work for an hour or 10 minutes. Sometimes not at all. Didn’t seem to matter the card. The cards worked fine in other cameras. Did seem to start after a firmware update. Finally got a new camera, at a discount, because the old one was just out of warranty. The new one, in the same position, same cords, same adapter, newer bigger SD card has been working fine. Knock on wood
Hi @JamesT6 , thanks for sharing your experience and the detailed update. I’ve replied to you via direct message.
Hi @Lm231, I’ve sent you a direct message to gather a few more details so we can look into this further. Thank you!
Hi @koz5544 , thank you for the update and for sending the logs. We really appreciate your help! I’ll pass along the product feedback to the team as well.
I am having those issues. I sent to log 2221066. The slow reformat appears to have worked.
I am having issues with all 4 of my Wyze Cam Pan v3.
    80482c5b92f4
    d03f27b57a81
    D03f27d851dd
    d03f279873cd
  • Camera model - Wyze Cam Pan v3
  • Firmware version
    4.50.16.5654
Cards that were working till firmware update.
GIGASTONE 128GB Micro SD Card 2-Pack, A1 V30 4K Video Recording, Compatible with Security Camera, Dash cam, Drone, 95MB/s MicroSDXC Memory Card UHS-I Class 10
PNY 128GB Elite Class 10 U1 microSDXC Flash Memory Card - 100MB/s, Class 10, U1, Full HD, UHS-I, Micro SDApproximately how long recording runs before stopping
    Will not format
    No SDcard (on ones the were working)
    No Video on card
    On cards that were working, they ere formatted preciously, won’t formate using Wyze app.PNY 128GB Elite Class
    I can put the sd card on laptop and see lots of video
I reformatted in exFAT on laptop. Tried them again, still fail.
Got different brand GIGASTONE 128GB Micro SD
Same issues with all 4 cameras.
The cameras will work 32GB and are being used at the moment.
I can put any of the 128GB in my Wyze Duo Cam Pan and they work. I get the DING sound. The app will format them while in the Duo.. I try one the 128GB which works in Duo Cam PAN into Cam Pan v3 where they still fail to be recognized with anything other than it needs to be formatted, which fails.
    After the update.
One more interesting note, I do have a Wyze Cam Pan v3.on firmware 4.50.15.4800 which will format 128GB cards that are not working with Cam Pan’s the newer firmware.
Hi @thillock , thank you for the detailed information. This is very helpful.
Could you please submit device logs for all affected cameras? That will help us investigate further.
If possible, we recommend trying the following steps before submitting the logs and letting us know the results:
If you’re unable to complete the steps, that’s okay. Please still submit the logs and we will begin our analysis based on the information provided.
One additional question: on the Pan v3 running firmware 4.50.15.4800, have you ever experienced SD card recognition issues with 128GB cards, or does it work consistently on that version?
Thank you again for your help!
No ding-dong, first says no SD card, then dialog come up to format SD card. This does not apply to camera Pan v3 running firmware 4.50.15.4800. I will recognize the all the 128GB.
  1. If there is no “ding-ding” sound, please check whether the SD card can be read and written normally on a computer.
They all can be read on computer.
Example
  1. If the SD card works normally on a computer, please back up any important data and format the SD card.
Did that in exFAT. Only fails when inserted in camera’s with recent firmware update.
  1. Reinsert the SD card into the camera. If you hear the “ding-ding” sound, please wait at least 1 minute and check whether recording resumes
Only Ding-Gong on firmware Pan v3 running firmware 4.50.15.4800
  1. If the issue persists after these steps, please submit a device log through the Wyze app. When submitting the log, please note whether you performed the steps above and include the Log ID.
2220753
2220755 Pan v3 running firmware 4.50.15.4800
