how do i get my Wyze cams to record when i view them…not continuously.
in other words if i hear a noise and check on it with the camera i’d like the camera to be recording what i view
The camera is already doing that depending on your setup. If you have Cam Plus or Unlimited it records to the cloud. If you have an SD card on the camera and set to events only it records to the SD card.
What type of camera do you have? Battery powered WCO v1 or v2, V3, OG, V4. If you want to record the live view off what you are seeing you can use the record button and the recording is saved to your device. I would just put an SD card in the camera so you can use playback. If you have a battery powered WCO it has to be set to scheduled event recording to the SD card.
Live view recording:
