This was happening before the big problems which happened a week or so ago, so I don’t believe it’s related.
I have 5 V3 cams, but the problem is only on one of them.
When I switch to live view, the timer doesn’t advance, it stays stuck at the time I initially start to view. If I exit and come back in, it stays stuck at the new time stamp.
However, if I switch to recorded view, it works fine, and shows the recording as normal.
I tried turning off and on, I tried replacing the power cube with another, but no change.
Firmware is 4.36.10.4054.
Anybody have any ideas as to what could cause this?
Thanks.
Recorded as in cloud events, or recorded as in SD card footage? Have you tried moving this problem canes to a different location in the house to try it another place?
Power and antenna might be fine, but the signal might not. As suggested, try different location. I have one camera that behaves like this and I can’t figure out what’s causing. Tried different cameras at the same location, same behaviour. I move the camera to a different location and it works fine. That particular location is causing some sort of interference.
in answer to Omgitstony:
I mean recorded as in SD card footage. That is working fine, but Live is not.
answer to Antonius
The KB/s shows 0 for the live view, but between 40 and 150 for the playback.
I was reading a while ago that there was a problem with stuttering on newer release, so I haven’t upgraded any of them for a while. I guess I should try that?
to Habib
I have another same V3 cam about 2 feet away, pointing in a different direction, and it works fine
Firmware of the problem cam is 4.36.10.4054, and the cam which is 2 feet away is 4.36.9.139
