Latest update breaks notification sounds 2.49.1
latest app update breaks android notification sounds for other apps
I load wyze video stream and exit app, then when I receive sms I get no notification sound, os thinks wyze is still outputting video sound. when I force close wyze then regular android notification sounds for other apps start working again.
I went back to 2.47, ever since 2.48 the app has been buggy on top of the video fade in which is annoying no thanks
I would recommend contacting Wyze Support over the issue. That way your experience can be logged and forwarded onto the appropriate engineer or dev teams for investigation.
https://support.wyze.com/hc/en-us
i submitted log file earlier yes, posting here for other people in case they notice their notification sounds stop working
Submitting a log is just the first step, once that is completed you need to follow the directions stated on the submitted log screen to then contact support.
