I am suspecting a connectivity issue with the app receiving the video data from the cam rather than the cam not recording. It will do that if the WiFi connection isn’t strong enough.
Load the card in an external reader And see if there is video in the Record folder.
OK, thanks for the advice, I’ll pull the cards and check them as one of the problems maybe.
Now as far a connectivity that’s surprising. The cameras are right outside front door but only 20 feet away from a Ubiquiti UAP-AC-LR. There is also 3 of them in the house so as far as connectivity goes, it does seem odd that it might be the case? Here’s the stats I just pulled maybe the bad link might be between the cell phone and the cameras?
NAME IP ADDR EXPIR AP / PORT DOWN UP TIME
Wyze Bobbi Car Cam 192.168.55.190 98% GANGNET LR WIFI 1.99 MB 1.74 MB 21m 7s
Wyze Art Cam 192.168.55.126 100% GANGNET LR2 WIFI 45.9 KB 117 KB 29m 35s
Wyze Back Yard Cam 192.168.55.135 100% GANGNET LR2 WIFI 180 KB 581 KB 23m 20s
Wyze Bed Cam 192.168.55.138 94% GANGNET LR2 WIFI 473 KB 2.12 MB 23m 7s
Wyze Daves Car Cam 192.168.55.166 99% GANGNET LR WIFI 30 KB 75.3 KB 22m 34s
Wyze Deck Cam 192.168.55.124 100% GANGNET LR2 WIFI 20.9 KB 98.3 KB 30m 22s
Wyze Front Door Cam 192.168.55.116 98% GANGNET LR WIFI 3.15 MB 272 KB 23m 9s
Wyze Living Room1 192.168.55.175 100% GANGNET LR2 WIFI 339 KB 1.33 MB 23m 26s
Wyze Living Room2 192.168.55.122 100% GANGNET LR WIFI 385 KB 1.43 MB 23m 3s
Wyze Side Yard Cam 192.168.55.132 100% GANGNET LR WIFI 329 KB 1.89 MB 22m 48s
Wyze Side Yard Cam 192.168.55.127 100% GANGNET LR2 WIFI 27.1 KB 101 KB 30m 19s
Can you make any suggestions that I can do or try to the camera to fix the connection issues?
Cam-to-AP speeds look slow to me. I have over 50 cams and the slowest is still over 100Mbps from cam to router using a Google mesh network with 6 APs.
Keep in mind that “link” is cam > access point/router (WiFi network) > viewing device, not cam > viewing device.
Try restarting “Car Cam” so it reestablishes a connection to an AP, tap Airplane Mode on your viewing device then tap it again to reestablish connection between viewing device and an AP. Then without moving around your house/yard, check Car Cam. Some phones/tablets get stuck and hold a WiFi connection even though you’ve moved to a location where an AP has a better connection leaving you with a poor connection to the farther AP.
If that still doesn’t work, unplug all 12 cams, replug Car Cam, wait for it to reestablish connection to network, run a throughput test and compare results to what you listed above. If the speed is still slow, your cam is probably not connecting to the nearest/best AP. If speed from cam to AP has significantly improved, also check speed between phone/tablet and AP.
What gets me is my access point is actually 3 separate Ubiquiti Access Points - one mini outside on the desk and two LR’s as well, one in the living room and one in the bedroom at the other end of the house, and the bloody place is only 1400 sp feet. (4 level split)
God knows why I’m seeing these crappy connection speeds. When I get motivated again I’ll pull the cards and get a few new ones and try that ex-FAT formatting and see what that does as one fix.
I’ll attempt to get on to the Ubiquiti’s forums and see if they have any suggestions for the cameras, they’re support isn’t that spectacular but with their cloud key as the controller you can see what’s going on in some places.
I have all the impt stuff on a gigabit network backbone anyway so at least the PC’s are happy.
Thanks a ton for the help and suggestions too BTW folks, its appreciated.
