IR light issue
Can anyone tell me why the IR light on my V3 is turning ON then OFF every 12 minutes . Set to ON FAR.
When the IR light turns off does it go to color (night mode turns off)? If so it may be in an area where the ambient light is right on the verge of the amount that triggers night mode.
Thanks for your input Dave27. This does not seem to be the problem. Possibly a bad V3 cam. Still investigating
If the IR lights are cycling on and off but the camera is staying in night mode, try a different power supply and possibly cable. If that doesn’t fix it, I’d get the camera replaced.
