initial setup of home monitoring bugs out with the error message below during the protection setup->home setup step
HMS id failed
HMS id failed
Is your 3 month HMS Subscription showing in the Account>Services>Home Monitoring header or within your subscriptions on my.wyze.com?
first experience with wyze home monitor is horrible, ordered $300 worth of core setup and various sensors, paired all the sensors and grouped them how i wanted just to have the monitor setup fail and customer support chat hasn’t for a factory reset on my hub which didn’t resolve my issue. wasted my time setting up my sensors. can’t get past this error during 0/3 protection monitoring-> home setup please fix this bug so that i get some satisfaction
[Mod Note]: Your duplicate post has been merged to conform to the Community Guidelines. Please avoid crossposting the same issue in multiple areas. Crossposting is considered spamming.
Just to let you know, the Forum is primarily a User to User platform wherein other users familiar with the hardware and software exchange information and try to help where possible. It is not a replacement for Customer Support. Wyze participation in the Forum is limited.
that’s fine, i’m a embedded software engineer at telecommunications company, i dont have any issue trying to resolve this with other users, i’ve posted on reddit, discord and here hoping to find someone with the same issue. i spend 30 mins with customer service and all it got me was a gift card offer and a email with the chat history. i don’t want my money back i want this bug fixed
It is most likely something with the iOS App. I am using Android so it isn’t something I can troubleshoot. If you were using Android, I would suggest an App removal and sideload reversion from an older APK version. Not sure that is possible on iOS. There is currently a Beta in progress that may do the trick, but that opens up Pandora’s box for possible additional issues.
What App version are you running?
another thing is they may be querying a flat database via nvm memory addresses, which could require a different level of factory reset
my plan is to see if i can get this resolved within 30days, if not, i’m shipping the entire system back to amazon as non functional, which requires me to scrape all the sensors off my walls, is what it is
or they ship me a dev unit and i can minicom into it to backtrace this error
That didn’t reboot the Hub, it Factory Reset it. This requires a complete new Setup of both the Hub and all Sensors.
A Reboot is a 5s press until the first lights flash. The Hub does not require a new setup and sensors will not need reinstalled.
ah, the hub has a subset of paired devices, i’ll take another look, that good that we can factory reset, it should clear the database, im not sure if the error is app clientside or hub serveside with a return error, it’s either the data payload isn’t valid before the send, or the api is hit and we get a error
this feels like a client/server version mismatch, api isn’t lining up
You aren’t the only user to have reported this so I would suspect an app issue.
would you happen to know where reported bugs are listed and where i can find out what bugs have been resolved for patch release? so that i can get progress reports of bugs being worked on and patches being release for some of those bugs
Known bugs are published on the Wyze Knowledge Articles Page at https://support.wyze.com/hc/en-us/articles/360032747431-Software-and-Firmware-Known-Bugs.
Bugs are usually reported and tested here in the forum quicker though in the App or Firmware update thread for the respective version.
Not knowing what version of the App you are on, the last App Update for iOS was for 2.46.0(6) on 10/19/23. The App Release Thread is here: Wyze app and firmware updates - Released 10/19/2023.
There is also a current Beta App (iOS v.2.47.0(1)) in testing being discussed here: Wyze App 2.47 Beta Testing 10/26/2023
