Great update, this introduced some really important features for this vacuum. Thanks for the quick work!
yep thatās what mine is doing also. it has been over a day like this now.
Anyone know of what hardware/design changes there are with the newer plug?
Vacuum was working fine all day aside form room editing. Now all of a sudden itās disconnected flashing white lights. I tried to reset and add the device about 5 times now and it keeps failing. It looks like many users are experiencing this.
Wyze I think your updates broke the vacuum can you please advise?
My vacuum is disconnected from the internet. A reboot did not fix this issue. Multiple people on reddit are having this problem as well: https://www.reddit.com/r/wyzecam/comments/l1kzar/the_robot_is_disconnected_from_the_internet/
My vacuum is blinking white lights as well. It shows disconnected on the wyze app. It is connected to my router and is pingable with some dropped packets.
Same - updated to 1.6.97 yesterday and it worked fine, worked this morning and now itās just flashing white and canāt get it to connect (it charges right new to my router). My camera clear out in the yard is connected just fine.
Iām having the same problem.
It seems this is becoming a widespread issue.
Same issue as well
Same problem here
I updated firmware a few days ago and edited the map. Our vac has run flawlessly. I read it clean one room today When I got home I had it come out from underneath the cabinet where it charges, (no problems with internet connection at all having it there), so that I could empty the dustbin. I had it return to the charger and it disconnected from the internet. First time in a month that has happened. I cannot get it to reconnect. I donāt want to set it up as a new device because I donāt want to lose the maps. Any suggestions?
Yes. I am. Just flashes white and shows offline in the app. App is up to date.
Mine just connected. Solid white light now.
Mine just came back online too.
Mine is online now
doooh - I updated the vac firmware 8 hours ago, then reset the vac wifi, and I deleted my vac from the app. Also updated the phone app. Did I just bone myself?
23 MINUTES LATER - after I deleted the original vac from phone app, then I was able to add a new vac, and I was able to make the network connection that would not go finish before. Ahhhā¦
I do get the feeling Wyze staff are watching this thread.
Hmm, originally I updated to .97 and everything looked great. Had it vacuum a couple of rooms. This morning woke up, opened the app, and it says the vacuum doesnāt have a map. Anyone else not seeing their map today? Wondering if I should have it remap, or wait a day to see if it comes back.
