Image hazy and distorted
Screenshot_20190827-011349_Wyze
I have 2 cameras mounted under eaves outside. The quality seems to be lacking at night. My inside cameras don’t seem to be distorted like this. Maybe because these are outside?
What does the image look like during the day?
Night vision is spec’d at roughly 30 feet (9m), but “very good” illumination with the IR lights only occurs at about half that. Inside shots are usually half the distance, so they typically look good. So I think your outside shots look reasonably typical?
Looks pretty normal. I have a v2 in an upper garage inside corner, the IR bearly gets to the opposite corner of the two car garage.
