I want more than 3 settings on my thermostat
I see that only 3 settings are set up in my thermostat: Home, Away, Sleep. That has caused my system to use both heating and cooling, even in a Colorado winter.
I want to set more changes, preferably to:
Morning 6am: 70-73
Day 10am: 72-75
Evening 6pm: 70-73
Sleep 12am: 68-71
I tried to accomplish this by creating two home settings and two sleep settings, but now the system seems completely confused (it just heated up to 72 at 1pm!).
Is there any way I can have four settings?
TIA
You can set the schedule to use whatever temperatures you want. the 3 settings (home/ away/ sleep) just set a default temperature.
Set up a Schedule for Sun, Mon, Tue, Wed, Thu, Fri, Sat.
Within this schedule set up 4 Schedule Blocks.
  • Sleep 0:00am 68-71
  • Home 6:00am 70-73
  • Home 10:00am 72-75
  • Home 6:00pm 70-73
When you create a Schedule Block the temps default to what you set in Temperature Preferences but you can override - just remember to ‘Save’ on each screen.
Here is my setup.
NOTE: To delete a Schedule or a Schedule Block - Swipe Left and you will see a Delete Icon.
