I wish you could set way more times on the schedule. You’re only able to set three different times. I installed this because it’s easy for an elderly person to use. Except if that elderly person keeps messing with it I want it to go back to a reasonable temperature quickly. It would be great if i could set it for every two hours to go to the desired temperature. This way I wouldn’t have to keep checking to see if it was moved. I don’t want to lock in at one temperature. Being able to adjust it is fine, but he’s blind and goes way high or way low on the temperature.
Hello @sammymob, and welcome to the commuunity.
See if this Wishlist entry is related to what you are looking for, if so add your vote.
