Can you schedule the thermostat without selecting a time?
Can you schedule the thermostat without selecting a time? I only want to set a temp for each Home, Away and Sleep without setting a time. Then when I select Home or away or sleep from the App it should stay on that temp until I change it.
If you don’t set a schedule, you can basically dial up whatever temperature you want, and it will hold it.
Ok, but it would be nice to have a the option to set a temp for each status of Home, Sleep and Away! Another cool feature would be to tie that to the security cameras and system. So that if you hit the Away mode from the App it would set your security to on and your thermostat to the programed temp.
Any thoughts on this from the community? Is this something other users would see valuable?
