Going to have to replace the camera that my subscription is assigned to. I need to know how to move it to a different camera
After you get your new cam setup on your WiFi, from a phone or tablet, go to:
Wyze app Home > Account > Services > Add Cameras (you may have to scroll down to see this) > uncheck your old cam > check you new cam > Close.
Then go to your new cam’s settings and set Detection Settings, Event Recording and Notifications.
I did that, but the the camplus icon is still showing on the old camera, Do I need to restart both cameras?
Double check to be sure the change actually worked. There’s been a problem with CamPlus changes not sticking.
Hi Travis,
Did you get this to work? I am about to replace three of my old V3’s to the V4’s and it seems like a straight forward switch. Did you manage to get the Cam Plus to transition over to the V4?
