Transfer Cam Plus subscription
I have an annual Cam Plus subscription currently connected to my Wyze Cam Pan V1. I would like to replace the camera with a Wyze Cam V3. Can I transfer the subscription to the new camera?
Yes,
all you need to do is go to the Account Tab, click on the CamPlus in the top left, then click the arrow to the left of the camera you want to remove camplus from. In the list select Unassigned and it will remove CamPlus. Then assign it to the new camera.
Here are a couple of images:
Thank you. That was very helpful.
Make sure whatever camera you are transferring it to is on the latest firmware.
