I need a silent, wireless alarm
I have been trying to buy an item that apparently doesn’t exist. I want a remote, WiFi silent alarm for my garage. Someone enters my garage, it senses the person is there and an alarm sounds not in the garage but in my home which is 60 yard away. This way I will know someone is in the garage but the person will not know that I know he’s there.
SO many uses for an item like this and I would imagine it would be among the simplest of products for Wyze to develop.
Welcome @semencic
If you are using a Camera, you can add one of these to your main house and have it notify you. This is a WiFi Chime, so you would have to be on the same Network.
In addition to that, if you use Alexa, you can setup a routine for cameras and sensors to notify you if someone is seen and target certain Alexa Devices.
YoLink can do this. Motion sensor and speaker hub. Or, Wyze cam with CamPlus and Alexa on an Echo.
You could setup however many v2, v3 or v4 camera’s it would take to cover where you hope to detect a person in your garage.
Then create an Automation to trigger one or more Wyze Color Bulbs in the rooms of your choice in your house (make it flash and/or turn it on to a chosen color).
That would be ‘silent’
I do this with Wyze Color Bulbs in my house.
When my Wyze Camera’s (placed outdoors) detects a ‘Person’, certain lights turn on Red for one minute.
If those same camera’s detect a 'Pet", I get a Green Light for one minute on specific Wyze Bulbs in the house.
You could create an Automation of your choosing, and experiment with it as needed. I’m not sure if you would need to have an active Cam Plus subscription or not.
