I have 2 OG cameras hooked up and working,
I bought another one and it will not connect, I time out before connecting, any helps
If you’re trying to set it up right near the router and it won’t work, may be a dud.
Just to be sure try putting your phone on the 2.4Ghz band in case something in your router is blocking something between the two bands (assuming your phone is usually on 5ghz). Worth a shot, it has happened before.
Do a factory reset on the cam (hold setup for like 15-30 seconds) just to make sure you’re starting from scratch.
