I changed my router, how do I change my network for my v3 cams?
I changed routers. How do I change network for my v3 cams
Easiest solution is to set the SSID and password of the new router (or more specifically, the WiFi part of it) so that it matches the old Wifi.
The hard way is to run setup on the cameras, again, without deleting them. You can change the ssid and password then.
