Currently, as far as I can tell, the sense hub only gives a verbal report that it is running on battery. When it is restored to power there is no “power restored” message. Heck, even if the hub had a power light on the side that would be better than nothing. I have my hub perched on top of a piece of furniture and I need a step stool to reach it. I suppose another option would be to add information into the app showing whether the hub is running on external power or battery. Need something, right now I just have to unplug it and then plug it back into to make sure it’s powered. I’m using a usb A extension cable so it reaches from the top of my cabinet where it’s perched down to the floor and a few feet to the usb plug on my wall outlet and dog has been known to somehow manage to tug on the cable and unplug the hub, if I taped it up he’d probably pull the hub off the top of the cabinet or get himself tangled in it.
Please make sure you Vote for your Wish Item. The system does not automatically add your vote
Great idea! I like it.
The hub currently sends a push notification if the server connectivity is lost. Would also like to see a push notification when it is restored.
The following would be great to have for audible hub announcements:
Connectivity Lost
Connectivity Restored
Power Lost - Running on Battery Backup
Power Restored - Charging Battery
In the App Device Info page, it lists how it is connected (Ethernet \ WiFi). It should also list how it is powered: Plug \ Battery.
I’ll take it a step further. My hub sometimes still says it’s running on battery even after power is restored!
This can go on for days. It will read 100% charge on the batteries for days, but still says it’s running on battery power.
Sometimes I have to unplug it, wait a few minutes, then plug it back in to get it to realize that it’s NOT on battery power.
I have seen that once.
