How to remove ear pads from headphones
So I finally found some replacement headphones on eBay since Wyze never has them. Any instructions on how to remove the old ones without breaking anything?
There are probably hundreds of youtube videos illustrating this; better than anyone can describe here in text.
if there are, I haven’t found them.
Do you need instruction on how to search, too?
lots of videos but none that address the Wyze headphones clip setup. I’ve tried pushing and twisting with minimal force to no avail. I hesitate to use more force without knowing if the clips will break.
I’m also having this issue; did you find a way to remove the pads? Thanks!
I just slipped a kitchen knife blade under the pad from the outside and twisted it, the pad popped right off with no damage. Then I put the replacement pads I bought on eBay on by simply popping them back in.
Thanks! I was going crazy trying to remove it, that worked for me :slight_smile:
Reach inside the cushion and pull outward. There are few clips in there that just snap together.
I appreciate that photo with both headset and ear cushion connections showing.
Also, the kitchen butter knife trick worked like a charm!
I was able to find Wyze Noise Cancelling Headphones replacement ear cushions via Ali-Express… They fit perfectly and they were rather inexpensive. (I bought 6 pair for future replaceability) Shipping was about 12 days including customs…
Thanks for the swapping method tips. They were very helpful!!
Hi! Could you please share the link to the aliexpress item you bought? I would really appreciate it!
Thanks!
I bought mine off eBay, https://www.ebay.com/itm/375359272622
$12.35
The Ali express link as requested…
https://www.aliexpress.com/item/3256806861793286.html
I purchased 6 pairs to support 2 pair of noise cancelling headphones
Thanks you @omandave and @thompson.ron.l
You guys rock!
