How to eject microSD card
Hello,
I have inserted a microSD card into my WyzeCam unit, but am unclear how to eject it. There does not appear to be an eject button and the slot does not appear to be spring loaded.
Thanks!
The card itself is the eject button. Use your thumb/fingernail to press in on the card until you feel/hear it click, then slowly pull your finger away. It’s spring-loaded and if you’re not careful when moving your finger, you could cause the card to go flying - this is how all microSD slots I’ve used work, not just this camera.
Thank you so much, it worked!
Does not work for us. We cannot get ours out of the camera.
You have to make sure you push it down far enough , It is not really easy To push it down all the way that it is needed
